Originally posted by vintagekiki
View Post
70s Ampeg V4B Blows Fuses
Originally posted by ca7922303 View PostThree(3) power tubes measured 1.2mv on pin#8, 4th power tube burnt up R28. Replacing R28 or can I leave R28 out to test more power tubes?
Replace R28.
If measured voltages as in your post #180 [# 3 (586v), # 4 (596v), # 5 (-63v)] and on pin # 8 tube V5 you have 1.2mv these are unusable tubes .
You should expect a voltage > 20mVDC on pin # 8 of tube V5.
What is the value of the sensor at pin # 8 tube V5?
Please upload photo V5 tube socket.It's All Over Now
Originally posted by vintagekiki View PostBurn R28 (cathode resistor V4 / 12AU7) 1k5 has nothing to do with measure 4th power tube (6L6).
Replace R28.
Replace R28.
1 Photo
The three(3) power tubes that I tested were tested in a tube tester at a amplifier service in Nashville, TN before I began working on this V4B. They tested good. Three(3) other power tubes I had with me also tested bad. I'm curious what could have caused them to be bad now?
Originally posted by g1 View PostAfter you get that socket working, try this test again to see if power amp & supply are still basically working: https://music-electronics-forum.com/...556#post929556
Originally posted by ca7922303 View PostI'm curious what could have caused them to be bad now?
Where is resistor 1 Ohm ?
Do you have any idea what you measuring ?
If you are really interested in the cause, get educated, study, read technical books.
This is just a waste of time.
It's All Over Now
Originally posted by DrGonz78 View Post1ohm resistor?
https://music-electronics-forum.com/filedata/fetch?id=930419&d=1619849061
It's All Over Now
Originally posted by vintagekiki View PostOnly one 1 ohm resistor, temporarily in the air ...
https://music-electronics-forum.com/filedata/fetch?id=930419&d=1619849061When the going gets weird... The weird turn pro!
Why are you chasing power tube quality, it is not important now. It was determined earlier (post #97 & 98) that the power amp was working and no signal was getting through the preamp.
Originally posted by ca7922303 View PostAppreciate that. Ran signal generator to ext. amp jack and am getting output. So preamp is at fault.Originally posted by ca7922303 View PostUnable to hear signal from V4b ext. Jack to other amps input.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
