Vox AC30 Vib/Trem Channel Effect Speeding Up
  • Vox AC30 Vib/Trem Channel Effect Speeding Up
    I have a 1993 Vox AC30 TB /6 amp where the Vib/Trem effect speeds up after the amp warms up. For the first 10 minutes of playing the speed for each setting (Vib and Trem) matches what is hear in this video: https://youtu.be/on1s6UjUCPY?t=231 After 15 minutes, each speed selection increases 2x or so.
    I have read this thread https://archive.ampage.org/threads/6..._C_Crap-1.html which was very helpful in understanding the circuit. Rick Erickson mentions that: “
    I have noticed also that many of the RI AC30's have rather unstable ceramic caps in the oscillator circuit and the osc. speed will vary considerably with temperature changes. A can of freeze mist and a heat gun are very handy troubleshooting tools for this kind of work.”
    This is indeed the case for me too, I spray a bit of freeze mist on the ceramic caps in the oscillator circuit and the speeds comes back to normal. I have replaced the .01uf ceramic caps with new ones and this has not made any difference. Any other suggestions? Are there any specific caps that prevent this issue? I’m pulling my hair out trying to get the Vib/Trem speeds stable. Thanks, Ross
    On the rare occassion that I have an AC30 in for repair with this sort of fault, I fit https://uk.rs-online.com/web/p/polye...itors/6224634/
    The circuit is a colpitts oscillator, very primative,. It relies on phase shift to work. If it is drifting wildly, as you describe, replace also the other components in the circuit, especially the timing resistors.
    There are many schematics and many versions, some with switches others without.
    I attach a sawn off simlpified re print of a typical vibrato oscillator and I would replace the R80, 86, 87 and 88 as well.
    Click image for larger version  Name:	Screenshot 2021-04-04 at 09.45.56.png Views:	0 Size:	27.1 KB ID:	928243
      Thanks so much for the reply, I will purchase those caps and replace the other resistors that you mention. I'll report back soon!
        Reporting back that the polyester caps were indeed a success! I ran the amp for over an hour and the trem/vib circuit remained stable. Thanks again Jon!
