Kustom iii Lead SC No reverb
  • Kustom iii Lead SC No reverb
    Checked tank and leads going back to board, all have continuity. Unable to track down a schematic.
    Look at Swedish table.
    Schematic Requests
    It's All Over Now
      Wondering if anyone has any ideas about reverb on the board?
        Schematic Requests
        https://music-electronics-forum.com/forum/amplification/guitar-amps/maintenance-troubleshooting-repair/33509-kustom-lead-iii-sc-ombo-reverb-issue-need-schematic
        It's All Over Now
          So all leads from board to ground have continuity. Here's photo of board. Wondering what component is associated with reverb besides the pot?
            Numerous components.
            Look on the board solder side, what number board is it? PC5083 or something similar.
              Did you measure DC resistance of the tank input and output?
              Basic reverb tests usually are to disconnect leads from the tank. Touch tips of leads with your finger, listen for some buzzing to come through the amp. This should only happen with one lead (the reverb return). If that works your return circuit is working (you can turn reverb up/down and make sure that is OK too at this point). If that works you can hook the tank up and bang on it a bit with the amp on, you should hear some crashing sound through the speaker. If that happens the tank is probably good. If both of these tests check and the DC resistances are right then it has to be in the reverb send circuit.
                PC5129
                  Here you go
                    Got the reverb going. Appreciate the help. Most of been corrosion, sprayed everything, plugged back in and all good. Thanks again.
                      Originally posted by ca7922303 View Post
                      PC5129
                      What about PC5129 ???
                      Get involved a little.
                      To win the premium, you must first purchase a ticket.
                      Here in front of you is PC5129.
                      https://music-electronics-forum.com/forum/schematic-requests/909590-looking-for-kustom-iii-lead-s-schematics?p=909592#post909592
                      And what's next?
                      It's All Over Now
                        Originally posted by vintagekiki View Post
                        And what's next?
                        See post #10
