I got the amp low cost because the mini 5 pin plug from the foot switch had been tripped over with enough force to leave the pins in the socket. I've replaced it with a full size 5 pin DIN socket and wired up a 5 pin plug to the foot switch cable, foot switch all working ok
pic
So next issue, the reverb only works on the clean channel but still with an issue, I can't switch it off, the button stays lit. If I switch to the crunch/lead channel the button goes un-lit and pushing the button does nothing.
The next issue is a common one, after 15 mins of use, the channel randomly switches to crunch, a known issue, overheating?
Doug.
pic
Doug.
