Fender FM 65
  • Fender FM 65
    Working on a Frontman 65 ..it came to me with a loud hum . I found some burnt resistors inside = R76 / 80 / 82 / 83 . I replaced those and the diodes that were right next to them since i have a boatload of 1N4448 . So D23 / 26 are new and ive tested every diode on the entire right side of the pcb .
    I found that Q9 was shorted . I replaced that along with Q 7 / 10 / 11 since the board was out and i had some in the bin.
    The 4 transistors on the big heatsink test good in circuit / no shorts . Q15 / 17 /18 /19
    Powered up with the bulb limiter and shes glowing bright.
    Any thoughts on what to look at next ?? I will pull Q6 / Q8 out and test since im getting funky numbers on meter in diode test mode (they test ok as far as ohms and no shorts there.
    Frntman65.pdf
    Do you have a load connected? Disconnect it. Does bulb still light? Is there DC on the output?
      yes , had a dummy load on. Took that off and bulb is dark , but ive got 32 VDC at the speaker out (with the bulb limiter )
      not showing a short...but could one of these be the culprit = Q15 / 17 /18 /19 ?
        " but ive got 32 VDC at the speaker out"
        Is that + or - 32Vdc?
        You obviously had a catastrophic blow out.
        Everything is suspect at this point as both rails shorted out.
        You need to get the bias set up.
        Q15 base: +0.6Vdc
        Q17 base: -0.6Vdc
        Remove the outputs for now.
        At this point if the limiter stays dim, remove it.
          Q15 base: +0.6Vdc
          Q17 base: -0.6Vdc
          its +32vdc at speaker terminals
          so as long as theres no load i can apply full power ? Im just nervous about burning up the new parts !
            Yes, just don't apply a load to it .
              thanks--i will look at it today
                I fired it up and within 10 sec i have some parts getting real hot. Verifying with a laser temp gun . Some are right next to each other on the board . Those would be
                D18 / 20 /21/22 , R75 ,R81 ,C51 , these all seem to test ok in circuit.
                Also getting real hot = Q6 /10 / 11 , Q10/11 are new .
                the 4 trans on the heatsink are staying cool.= Q15 /17 /18/19
                ill pull Q6 out of circuit and test it ..............does the above info help? any parts to focus on?
                  You never checked the bias voltage at the driver transistors?
                  If you did, please specify what you measured.
                    That would be on the base correct ?
                    Q15 /17 /18/19 all have +42v or -42v at center leg
                      Center leg is Collector so + or - rail respectively.
                      So we know we have rails but nothing on transistors themselves.
                      To measure biasing measure base to emitter.
                      Check datasheet for pinout.
                        i could only find data that said EBC left to right , i guess that was wrong
                        so B to E i get =
                        Q15 .58V
                        Q17 .93V
                        Q18 .58V
                        Q19 .58 V
                          Voltage drop on Q17 is too high. It is likely bad.
                          Edit: To be sure, the basing diagram on that transistor is BCE and it is a PNP. Polarity matters. You didn't state polarity in your measurements. A transistor wouldn't have a .93V voltage drop B-E forward biased. It might if reverse biased, indicating a different problem. So, remeasure and tell us the polarity base to emitter and/or remove the transistor and check it out of circuit.
                            sorry --- the above measurements were with transistor in circuit , amp power on , voltage mode on meter .
                            so red lead on base , black on emitter , +.93 vdc . Reverse the leads and its - .93vdc
                            i took the trans out of the board and in diode mode on meter i have normal readings of 0.6v b /c ( and 0 leads reversed) , but 0vdc both ways on C and E
                              On diode range 0V indicates a short. So the transistor is shorted between collector and emitter. Replace it.
