The reverb works until the footswitch is plugged in.
Here is how the footswitch (P/N 040513 A) is operating
Channel Select - toggles red and off (no light). Amp does channel switch,
Gain Select - toggles red and green. Amp does toggle gain mode.
Reverb - toggles red and off (no light). Reverb is off in both positions.
Schematic attached implies that all three LEDs should toggle red and green. But it has a different P/N 040515.
All of the LEDs have 3 legs. So I am thinking that the green led portion is never turning on and that is why the reverb is not turning on. Both diodes near the reverb switch test good. OL in one direction. .58 in the other.
This amp uses a speaker cable to connect the footswitch to the amp. Is the reverb being toggled to ground to keep it off? Problem at switch or at amp?
Thank you! MC
fender_roc-pro-1000_sch.pdf
Thank you! MC
