Good Day Gentlebeings.
I built this Marshall 1987 clone last year. IMO it sounds absolutely amazing but I can't seem to track down this noise. It is intermittent and sometimes rather explosive sounding. It is sort of a static sound, what I would relate to a bad resistor, but can find no culprit... yet. First, I attached a short 13 second long audio clip that starts with the noise and you will hear it abruptly stop after six seconds.... then I will list what I have done and things I have noticed...
SL50 Noise 3.mp3
First thing I notice is that the noise does not happen until the amp is at full operating temperature... so usually about 15 to 20 minutes after it is on and I have been playing. But it isn't always at 15 minutes... sometimes I can play for an hour before it starts and occasionally it doesn't happen at all, after two or more hours of use.
Sometimes it is quiet, sometimes louder (as in the above clip)
The tone controls effect the sound particularly the Bass control, the gain pot does not. This should more or less narrow it down to v2 - and when I pull valve v2, the sound stops. When I put it back in, it occurs.
I have changed the v2 valve two or three times - having used known good valves.I should probably do the same on v3 for good measure.
I have gone through with an oscilloscope. I have done this several times, waiting long enough for the noise to occur. But I have not had a lot of luck. I am not tracing a signal, just waiting to see some noise on the oscilloscope. The other day, after several attempts over several months, I got a noisy readout the pot side of one the 22nF caps in the tone stack... I replaced it and thought it worked, but the noise finally came back after a few hours of playing. This is what I recorded and added above.
Coincidentally, I previously had an issue with red plating this same amp, posted here...
https://music-electronics-forum.com/...ing-in-50-watt
Again after some months of troubleshooting that, I began to discover the amp was experiencing some type of slow moving bias runaway issue where the bias on the one power valve (EL34) in question was rising over time. But that is not to be part of this post, but rather to explain that I have a "problem child" on my hands. After changing the bias feed resistors at the PI and the grid stoppers to the EL34s, it seems to have halted for the time being but I did not perform any exhaustive tests to prove this with certainty. I only tested once that the bias was not rising on the one tube and left it there.
Extra info:
I had a cache of NOS Piher resistors that I used on this build. Caps are Sozo Next Gen. Power filtering using new build ARS 50uF @500V. Voltages in general look good... heaters at 3.3VAC which I know is a bit high... but unfortunately this transformer only came with a single 230V tap. Wall voltages here typically hover around 232V to 235V.
Here is the schematic... the only difference to my actual build is that I used a 250pF bright cap in lieu of the 500pF on the schem.
Any help or ideas is most greatly appreciated. Thanks!
SL50 Noise 3.mp3
Extra info:
