Sorry if this is the wrong place to post this..looking for a 200S schematic with solid state rectification. Are the filter caps the same as the tube rectified version?
Sunn 200S
Maybe the GZ34 was removed and diodes fitted in place.
This amplifier is from the Dynakit Mk3 range (from memory) and uses a GZ34, two KT88s as output and a couple of phase splitter/ driver valves depending on who built it.
I would think the capacitors are the same value as to increase them will possibly put a strain on to the transformers HT winding.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Well, here are the schematics:
https://irationaudio.files.wordpress.../sunn_200s.png = Tube Rectifier
https://el34world.com/Forum/index.ph...ch=62586;image = SS Rectifier
The 30uF is in a different spot, but that makes no difference."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
The 30uF is in a different spot, but that makes no difference.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
