52 Bill had commented on the main problem with these Kustom amps is the fragile Blue Push-Button Switches. Sure enough, after setting aside the Vox Beatle to open this amp up, there they were...both switches improperly mounted by Kustom, so repeated operation of the switches over the years caused the threaded plastic mounting bushing to break away. Why use a second lock nut when you can leave one off, since the mounting bracket was formed wrong....and just use the stength of the thin plastic to get the switch to be where you want it mechanically? So, all these years, these switches break one after another, and there is no direct replacement for them. That's good solid engineering, aiming to boost sales of replacement parts in manufacturing! Detroit has been doing that one for years!
I played with a couple tie wraps, to see if I could just hold it together long enough to slip in with lacing tape and spot-tie the switch back into place. But the mechanics of the switch is such that the only solution with these existing parts (can't buy replacements....all gone years ago) is to glue the plastic threaded bushing back into place, then build up the surface surrounding the switch body and the bushing, while disallowing any of the epoxy to seep back inside to kill the mechanics of the switch. So, I'm going to attempt bonding that threaded bushing on both switches back into place.
Then, add the second lock nut that SHOULD HAVE BEEN USED IN THE FIRST PLACE! That takes the stress off of the switch body!
Now, to see if this plan will work. First need to glue the bushing back into place, mating the two broken halves as they should align, and clamp it into place. Then, lay a bead of long-cure epoxy around the bushing/body to form a short boss and hope that will be enough to use the two thin lock nuts & thin ITL washer under the upper mtg nut. Those are the same thin 1/2' ITL washers I place under both sides of the fuse holders on current/recent Fender Combo amps, as the fuse holder is always loose! Will this plan work? The white plunger slips out of the bushing easily enough, it being accessible behind the mounting flange of the switch body. I'll have to wait until Tuesday, as the building here will be closed tomorrow.
The Second switch....is the Death Cap switch, so it's not really needed....but...can't leave a vacant hole in the panel, even though having a replacement switch on hand is tempting.
