Hi folks
I took a week or two away from my Proamp Viper 60 210/ KMD gv60 restoration to give my brain a rest.
I did another guitar plugged in test. Two things are obvious problems:-
1) Volume coming and going. If you play a 2 octave scale, it will start clear (although a bit distorted) and the die away ( same sound as when you switch off an amp and keep strumming using up the charge in the capacitors), then the sound will pick up again. Some notes (frequencies?) are quiet, others are really loud. A hard strummed chord will sound loud, albeit distorted. When it’s loud it is incredibly loud.
2). The second issue is the tone control. Dial all tone pots to zero and the volume also turns down to zero.
Before I start swapping pots, is there anything about these symptoms that points at a particular issue or set of issues?
Cheers
steve
Cheers
steve
