Someone had hardwired the 6.3VAC windings directly to the output board heaters which does connect thru the ribbon cables to the rest of the heaters. But in tracing the circuit, I see that there is a DC elevation ckt on the PS board as well as the 8A fuse. I don't think the elevation circuit or the fuse will work like this and I'd like a 2nd opinion on my thoughts.
Also, I was trying to trace down some hum the amp has. Whoever did this heater job also replaced the main 100u filter caps so I'm assuming they're OK. The only other caps would be the odd value 200u/75v bias caps and a 1000u/50v heater elev. cap. How critical are these cap values? So far, they're impossible to find.
