Ive got a Rivera Jake 50w here. No bias voltage. Checking with no tubes in it . Ive checked everything in the bias circuit . I also replaced C204 , c205 , c9 , c10 . Swapped out D5 with 2 different diodes even though it tests good in circuit . Replaced the bias adjust pot .
0mv at either side of R5 and D5 . 0mv at tube sockets . The factory did not use the "Poly switch" you see right after the power trans it has a jumper there. This amp has 1 owner and never been opened.
So........its got to be the power trans ???? If i put tubes in it they red plate within 10 seconds and the bias skyrockets up !!
Heres a scem of the 100w version .
