First, the amp came to me blowing fuses. Bad filter cap. I put a temporary cap in to get it running and check it. I found a few resistors way out and another bad cap.
But I also found the bias was around 146mah with a bias probe. I shut it down super quick.
I retested the power tubes (I tested all before anything). They were good on my tester. He said they were original (mid 70s). I put another set of tubes in just to check it. 145mah
bias voltage is -48v. Plates are about 496v. At the center tap of the output transformer, it’s not even a volt different. (Not sure if that’s right? The schematic shows a bigger difference)
i checked the coupling caps between PI and outputs and they were good. I even checked bias with them disconnected, same.
where should I look next? It seems too high to just need a resistance change. Especially since it’s got the USA tubes that he hasn’t changed (or if he did, it was long ago) and it was working.
i don’t have the schematic with me now. I can post it if needed.
