Power off question
  • Power off question
    Hi. Please let me know how much are endanger the power tubes when cut power off please? Have an amp I wanna get rid off stb. switch from pop noise reasons (it not really need it) but have lots of concerns when cut the voltage off. There is a bank of hefty 2000uF power caps installed, the bias voltage will drop very fast. Will be the power tubes in danger or excessive stress please ? I consider the power tubes will dissipate the max power in respect with a rate of bias voltage drop off but still not very clear for me...
    I think to use a power switch contact to disconect the shunt bias resistor to ground This will avoid to create a path to discharge the bias capacitors and will raise the bias voltage to max negative value it can provide. No good ? Thx.
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
    2000uF on the HT seem too much to me!
    Schematic would help but if you switch the screen grids, no thump because the bias voltage stays stable.
      Thank Jon. Is a 4 x kt120 300w amp. There is a heavy thump- the driver is supplied from the same node as the screens so big transient at startup . Anyhow the ideea of raising shunt bias resistor from the ground is brilliant. The max bias voltage last "forever" in bias caps leaving the power caps to discharge as slow without endanger the power tubes. It is a power switch circuit used in old Dynacords. Simply smart.
        See how this problem is solved by Dynacord (switch S3I and S1III)
        It's All Over Now
          Thanks. Yes, that I talking about.
            SOme wiring might remove the condition but not the "problem." This isn't a problem. You might find a small fraction of a second where bias and B+ are not exactly in sync, but it is over in a tiny period of time, nowhere near long enough to harm anything. As soon as power is removed, not only do supplies start to discharge, but the heaters go off and tube ability to conduct current drops off extremely fast. Consider, of all the tens of thousands of amplifier products out there over the decades, how many had some special circuit to hold up bias supply at power off? And of all those amps, how many were infamous for killing power tubes?
              If you are an opponent of standby sw, the solution is on / off delay timer.
              http://rubli.net/HT_delay/htr214xp.html
              A Start-Up Delay For Vintage Amplifiers
              https://www.diyaudio.com/forums/tubes-valves/89799-time-delay-relay.html
              B+ time delay relay
              https://sound-au.com/project39.htm
              Soft-Start Circuit For Power Amps
              https://sound-au.com/articles/soft-start.htm
              Soft Start Circuits For High Inrush Loads
              1)
              https://www.audiophonics.fr/en/softstart-protection-c-418.html
              Softstart & Protection
              https://linearaudio.nl/sites/linearaudio.net/files/AX1402JanDidden.pdf
              Tube Amplifier High-Voltage Delay
              2)
              https://diyaudiostore.com/products/soft-start-speaker-turn-on-delay-and-dc-protector-boards?variant=5940139268
              https://cdn.shopify.com/s/files/1/1006/5046/files/SSSchematic.jpg
              Soft Start & Speaker Turn-On Delay
              It's All Over Now
                I'm with Enzo on this. It's simply not an issue. I've seen plenty of vintage Champs and Princetons that still have good factory original tubes in them.
                  Why not just increase the bias filter cap to "match" the huge 2000µ B+ filters regarding time constant?
                    ...... Yes, or replace the 2,000uF overkill caps to a more reasonable spec for a tube amp.
                      See how this problem is solved by Carver
                      Click image for larger version  Name:	CarverSilver7A.gif Views:	0 Size:	114.0 KB ID:	935380
                      https://ampslab.com/SCHEMATICS/CarverSilver7A.gif
                      It's All Over Now
                        I like this option better than bumping the value of the bias cap. I haven't done bench tests but in cad sims I have noticed that excessively large bias caps can take a surprising amount of time to stabilize.
                          #10
                          Replace caps is not a solution because it eliminates the consequence, and the cause still exists.
                          It's All Over Now
                            VK, Could you please use regular quotations, like everyone else so that a person doesn't have to scroll back and find your reference?
                            I'll again reiterate, this isn't really a problem, so there's nothing to be solved, IMO.
                              Increasing bias filter capacitance will create a new problem of slow ramp-up of bias voltage, won't it? So you will be missing bias at power up rather than power down.
                              And does it not also create problems with LF response?
