Mates:
One of the amps in my friend's collection is a Hiwatt Custom 50 DR504 head. The amp is working but there is a modification that doesn't make sense. As of yet, I have not dived into looking to see exactly what is going on. But.... here is a summary.
The typical Slave output jack has been replaced with a pot. When you turn that pot, it affects the output level (on the far right output jack). I have the selector set to 8 ohms and using an 8 ohm cab. So it is as if that pot is tied into the preamp section somehow. That doesn't make much sense since this amp has pre gain and master volume pots.
But before I go diving into this amp, my question is this....
Looking at the schematic, it appears the Slave Output is being fed from the 16 ohm tap. Ig nothing is connected into the jack, you have a 3.9k plus 100 ohm resistor going to ground. But when you insert a cable, the signal goes through the 3.9K through the cable and returns to ground. Is that it? So my assumption is that if someone did not use the Slave Output they could either (1) leave the 3.9K and 100 ohms connected into the circuit with no jack or (2) remove this circuitry and be done with it.
Schematic - Hiwatt_50w_dr504_Schematic.pdf
Thanks for the advice....
