Originally posted by J M Fahey
View Post
Fixing tube broked pins
- Likes 2
Originally posted by Pedro Vecino View Post
I think that a direct solder of a wire on a pin cut practically flush without any other type of contribution in terms of mass could not even support its insertion in the socket.
I have solved that problem, not in case of broken pins which I consider non-repairable but to mount tubes horizontal due to absolute lack of space (inside a pedal sized Hammond case) by using individual female contacts, the crimpable ones used in female .1 pitch connectors, each with an individual wire which can be soldered to PCB wherever needed, turning Novals (and 7 pinners) into a sort of "pencil tube" with its hair thin flying leads,but more reliable.
Such contacts are short, you canīt insert tube pin fully, but grab it tightly (they are undersized for a 1mm tube pin).
I wouldnīt rolltubes once a week as some do but for normal use they work well.
Oh, and individually heat shrink them.Juan Manuel Fahey
- Likes 1
Originally posted by drewl View PostReminds me of the people in Cuba keeping those old cars from the 50's running with all kinds of weird parts."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostThis is a piece of "history" from a communist period 50 years ago when nothing was available on the market in my country and techs looking for desperate solutions...
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Many years ago...many...I used safety pins in electronics. I was into radio. I had a galena crystal, we unbent the pin partway and screwed it to the wooden chassis. The point was then used to find a sensitive spot on the crystal to act like a diode for detecting radio signals.Education is what you're left with after you have forgotten what you have learned.
Point contact diode of some sort. That was how people had to get their radios to work in the early days. That is why diodes are still sometimes known as crystal rectifiers.
https://en.wikipedia.org/wiki/Crystal_detectorEducation is what you're left with after you have forgotten what you have learned.
- Likes 1
Problem is that alloy used on miniature tube pins does not "take" solder.
I still have no idea what is going on with this fix. If I could see the stubs of the original pins that might help, but it looks like there is nothing there.
At a quick glance, I would be more likely to think that those supports were put there to help keep the top cap in place.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
