Peavey Triple X - high frequency oscillation
  • Peavey Triple X - high frequency oscillation
    This amp's owner complained of bad noises. I found burned open screen resistor R64 (400R/10W) and replaced. All other components pass inspection. Amp sounds OK at idle now (I have kept the bias at minimum for testing--seeing 470v plates and roughly 15mA each 6L6). Issue is, 10-11KHz oscillation blooms as master volume is turned up past noon. I can hear the pitch, and energy consumption rises quickly from ~80w at idle to ~120w when oscillating.
    Oscillation happens ONLY if external speaker is connected; no oscillation if running on resistive load only.
    Oscillation does not happen if V2 pulled.
    Using scope, I start seeing the oscillation at large amplitude just after V2B (see green circle on my schematic screenshot). Tube swaps don't change anything.
    I will try using various snubbing techniques on V2B, but happy to hear anyone's suggestions.
    Schematic: https://www.thetubestore.com/lib/the...-Schematic.pdf
    http://amps.monkeymatic.com
    I tried touching a 470p ceramic across plate resistors R2, R7, R4 in turn. No change to oscillation.
    What's the other obvious approach? Is it snubber cap from plate to cathode?
      You say, "Oscillation happens ONLY if external speaker is connected; no oscillation if running on resistive load only". Then, oscillation is traced back to V2. I don't see an electronic signal path between the two, so I'm wondering if the oscillation is due to mechanical or magnetic coupling. Is this a combo or a head? If combo, try a speaker outside the cabinet and see if oscillation is still there.
        This is a head. Speaker cab is a few feet away.
          I see no signs the filter caps are failing, but is this a possible vector?
            I'm not saying it is or isn't. There are plenty of possibilities. I will say that I just, 1/2 hour ago, finished up a Vox AC15 that was oscillating at about 24K. A new main B+ filter cap solved the problem. I found it by temporarily clipping in known good caps across the existing ones, while monitoring the oscillation, and found the bad one. FWIW: The bad cap tested perfectly fine out of circuit.
              Clipping a fresh 47uF into each node made no change in the oscillation.
                Found it! 1n cap from anode to cathode (pins 1,3) of V3A solves the oscillation. 470p didn't do it, but 1000p did.
                  glad you solved it but IME these amps work great without adding extra caps IFF all the other components are working!
                  The Illi-noise (sp?) PS caps spec'd on these are NOT long lived; they will need replacing eventually.
