I have a Randall solid state amp that my son loaned to a friend. Needless to say , it was brought back with a broken volume pot. It was broken completely off the board. Of course, they say it “just fell out” but the indicator plate the pots are bolted on to tells a different story. Anyway, I changed the pot ( put a 500 ohm in place of a 100 ohm) and turned the amp on, plugged a guitar in ( with a good chord, mind you), and… NOTHING! My question is, could the pot not have a good connection? Could other pots be broken internally causing this issue? Or, could it be a jack? I tried both jacks ( one is active and the other passive) and I get the same thing on both ends ( just a very faint electrical hum) and when I turn any of the pots, I’ve got nothing. Any ideas anyone? Where do I start?
Need help repairing amp
OK, so the broken pot. Was it broken off where the three legs come out? I'd wager what happened to that pot probably happened to others on the panel. They could be not snapped off completely but still cracked. ALso check the pc board they solder to for cracks.
How do pots break? SOmething can fall onto them, like a guitar propped up that falls over, and the headstock WHAXKS the controls. Or the amp falls on its face onto something. Or bouncing around in a car trunk it gets whacked. An amp that gets dropped can snap off parts. Etc etc.Education is what you're left with after you have forgotten what you have learned.
Hello to all, new member but not new new to the amp repairs trade...I second what Enzo stated, check the whole front end under strong light with magnifier glass and as for the pot being a 100 ohm thst is a little low for that as it may be 100k or 50k.
I'd look at the schematic drawing and trace it out.
If more help is needed I'm sure your find it.
Kind regards.
Randall schematics
https://el34world.com/charts/Schematics/Files/Randall/Randall_Schematics.htm
https://www.schematicsunlimited.com/r/randall
https://elektrotanya.com/showresult?what=RANDALL&kategoria=All&kat2=All
http://spaceryerson.com/pics/img%20RG80-A-SCH234.jpg
https://www.scribd.com/doc/278908103/Randall-RX120D-Amplifier-Schematic 1)
etc ...It's All Over Now
