This one came to me with main fuse blown and on opening found plenty of cowboy fiddling done with silicone sealant bloted on the tag board and slap dash wiring...so down to work and looking the schematic up found 2 different types being 100w and 135w types, this one being the 135w type.
Someone had removed the master volume switch function via cutting the cables and removing the 12k resistor, next they soldered on v4 pin Kathode with a 820 plus 2k2 and parallel wired a 220uf cap across it to ground and pin 8 with 820 ohm with 100uf to ground.
The circuit drawing shows pin 3 and 8 linked together and shared 820 ohm with 20uf across it to ground.
I've put the amp back as the spec circuit and removed all the mess and mods.
These amps look alot like the fender twin reverb.
Anyone seen or spent many an hour putting things back to stock after the youtuber wannabe tech has had a go.
