It came in plugged into the reverb jacks on a sliverface Princeton Reverb that the reverb was not working. Turned out to be a bad solder joint in the recovery section, so it was an easy enough fix, and happy the tank is not bad, because this amp is almost bone stock. I ran it by Nick at Magic Amps, but he says it is nothing of theirs. It measures 24 ohms tip to sleeve on the red dot side, and 1163 ohms tip to sleeve on the other side. Tip to tip is 1140 ohms.
What could it be?
What could it be?
