Have I mentioned that I dislike Mesa amps? They almost always cost me money. The only reason I am not pulling out tufts of hair is that Sydney is in lockdown again and I have few other repairs. This time I am doing battle with a Bass 400. The schematic looks simple enough, but this is where Randall Smith’s evil genius lures in the innocent, then slams the trap shut.
The noise is that typical crackling plate resistor sound. The noise is affected by the Master but not the individual Volumes. The noise is still present when V1 is pulled, but removing V2 brings blessed silence. Easy, me thinks. Just change the 100K plate resistor on V2. No luck. Better clean the valve sockets, input and Send/Return sockets. Nope. Still crackling.
I made a little sound probe to plug into a battery-powered amp to pin down the noise. It works a treat. In the attached drawing “N” means “noise at this test point” and “S” means “Silent, except for the usual valve noise”.
The schematic didn’t quite match up with reality, hence my little sketch. I also replaced the 100K and 10M resistors and the 250pF in the tone stack. I hope I’m wrong, but it's starting to look like the Treble pot with the Switch piggy-backed. That would be a major PITA requiring the removal of a Mesa PCB and tracking down a part from the new Mesa distributor, so I am very much hoping that you have another suggestion.
