Bogner Shiva blown flyback diode
Orange colored trimpot is probably in switched power supply, do not adjust without schematic.
https://www.rsdsound.co.uk/product/replacement-tube-heater-supply-smps-for-bogner-shiva/It's All Over Now
Originally posted by vintagekiki View PostOrange colored trimpot is probably in switched power supply, do not adjust without schematic.
Originally posted by ZoutoSo it would be good to have the right schematic or some instruction for setting that trimpot,test points, Voltages etc. I‘m not quite sure whether the actual setting of the pot is ok.It's All Over Now
Before adjusting 12.6VDC, measure the real heater voltage between pin4 and pin5, tube V1 and V4 ( 12AX7).
https://www.rig-talk.com/forum/threads/obnoxious-hum-on-bogner-shiva-20th-anniversary-head.178796/
Obnoxious hum on Bogner Shiva 20th Anniversary head
It's All Over Now
I don't think anyone has read the data sheet on heater voltage tollerances. The manufacturers state 10% + or -.
So if the voltage is 11.5volts, that is within tollerance, so no need to play with it.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 1
Yes. Good comment Enzo.
If measure in circuit it will read about 250 Ohms both ways, making the less experienced amongst us believe it is faulty.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by ZoutoWell, measured both ways it read 2.2 Ohms, it was definitely shorted.
If with the relay winding, connected parallel flyback diode, remove it and measure the resistance of the relay winding itself.
May be a diode damaged (in short circuit) and you have incorrect results.It's All Over Now
Originally posted by vintagekiki View PostDid you measure in both directions 2.2 Ohms, with or without a parallel connected flyback diode.
- Likes 3
