AC Dummy load transformer tester
  • AC Dummy load transformer tester
    So I was listing to the ARRL Electic tech podcast an this ham was talking about an AC Dummy load transformer tester. i got the pages and thought I'd share and see what you guys thought.
    The schematic has an error which i've included the correction.
    nosaj
    QST.pdf ​​​​​​​
    QST.pdf
Name:	Figure1 - Corrected.bmp
    Basically on the podcast he was using it to identify specs of unknown transformers
    nosaj
      The schematic in QST is correct.
      Click image for larger version  Name:	Low voltage AC load.GIF Views:	61 Size:	81.4 KB ID:	938395
      The diode is an internal part of the N-Channel Mosfet transistor IRF542
      https://datasheetspdf.com/pdf/1322671/STMicroelectronics/IRF542/1
      Click image for larger version  Name:	IRF542-STMicroelectronics.jpg Views:	58 Size:	772.9 KB ID:	938396
      It's All Over Now
        The original QST circuit is wrong, as the two body diodes would short one of the halfwaves of the transformer under test.
          Dummy load for transformers and power supplies
          https://www.eevblog.com/forum/projects/ac-electronic-load-circuit/
          AC Electronic Load Circuit
          Click image for larger version  Name:	test circuit.GIF Views:	0 Size:	62.7 KB ID:	938404
          test_circuit.pdf
          https://www.deeptronic.com/wp-content/uploads/2013/10/Power-Suplay-Tester.gif
          Power Suplay Tester
          http://danyk.cz/zatez_en.html
          Electronic resistor - variable dummy load for power supplies
          Click image for larger version  Name:	zatez.png Views:	0 Size:	1.7 KB ID:	938406
          It's All Over Now
            I don't like the corrected version either, because it won't work symmetrically:
            While the bias of the upper Mosfet is essentialy constant during its conduction phase, the bias of the lower Mosfet varies with the momentary AC voltage.
            This makes the active load non-linear and introduces DC current. Consequently the results will be flawed.
            I think the gate voltage supply should not be grounded but connected between gates and sources (i.e. floating).
              Mosfet transistors IRF542 should represent some kind of "strength (power) electronic rheostat" in the Dummy load function.
              simplified schematic
              Click image for larger version  Name:	ac-load.GIF Views:	0 Size:	21.5 KB ID:	938420
              It's All Over Now
                #6
                Click image for larger version  Name:	image_55781.gif Views:	0 Size:	82.1 KB ID:	938450
                1)
                QST_julio .pdf
                page 52-53
                It's All Over Now
                  If you go to this link they have the amended link for the corrected schematic I linked to in the first post as well as the podcast where they discuss it. show 39
                  nosaj
                  The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
                    The diode is an internal part of the N-Channel Mosfet transistor.
                    In that case on corrected schematic should be displayed a complementary P-Channel Mosfet transistor.
                    1)
                    https://www.eevblog.com/forum/testgear/adjustable-ac-load/
                    Adjustable AC load
                    Click image for larger version  Name:	LoadCircuit.jpg Views:	0 Size:	30.1 KB ID:	938459
                    It's All Over Now
                      I already said what I don't like with the (corrected) circuit.
                      Generally the loading graph (V over I) of a transformer is a straight line, so the uneven curve shown in the article can't be real.
                      I suppose it reflects mains voltage variations during measurement.
                      The voltage of a transformer drops with increasing current according to V = Vo - Ri*I, where Vo is the open circuit voltage and Ri is the internal resistance of the transformer.
                      As this is a linear function, the graph is a straight line and Ri determines the negative slope.
                      (The core has no influence.)
                      To construct a straight line it takes only 2 points. As the open circuit voltage at I = 0 is typically known, one needs only one more V-I pair to draw the graph.
                      So a single load resistor suffices.
                        Please share you suggest in schematic form, will be helpful to interested DIY builders.
                        It's All Over Now
                          In the "corrected" version from post #1, the Mosfet source terminals are interconnected (in the middle).
                          My proposal is to lift the gate supply zero from ground ( no ground connection required) and connect it to the common source point instead.
                          This makes sure that both Mosfets always have equal and constant Vgs bias.
                          But still the Mosfets would have to be selected for balanced operation. It is essential that the load resistance is the same for positive and negative currents.
                            Schematic please if possible.
                            From the comments, I can't imagine how the AC Dummy load practically (schematic) looks.
                            I have been successfully using a power supply load similar to www.deeptronic.com for ten years.
                            It’s not AC Dummy but it does the job.
                            1)
                            https://www.deeptronic.com/electronic-circuit-design/variable-dummy-load-for-power-supply-testing/
                            Variable Dummy Load for Power Supply Testing
                            It's All Over Now
                              What´s wrong with plain old wirewound resistors?
                              Robust, symmetrical, linear, cheap, and .... ummmmm ....... "resistive"
