Peavey Classic 30, preamp tube filaments wont light. Found a broken jumper causing pin 4 of V1 not to see ground. Thought that was it. Well, that was undoubtedly part, but nope. Now here's the kicker: Tested the -36V supply, check. Tested voltage drop across pins 4 and 5 of each tube, getting 12v ish drop across each tube. Changed tubes. Same readings, but tubes still won't light and are not working. Plate voltages present.
Since the filament supply voltage is present and the expected drop across each is present, I'd expect they'd light up and work, but nope. Any ideas?
