Hi all! I've got a troublesome Laney that's puzzling me at the moment. I was having issues with a persistent 100hz~ hum and given it's age figured a cap job would probably solve it. This done and a new set of valves installed I fired it up again to find, guess what, it still hums.
Have read through a number of threads here and at other places but can't seem to figure this one out from any of the advice. Here's the strange thing - the noise stops (or at least is bearably gone) when the chassis isn't installed in the cab and is also lower in volume with it resting in the cab but 'inside out' - but when installed it's loud and seems to push the amp towards popping the HT fuse. Voltages across the amp seem fine (they're a touch high but apparently no higher than Laney expected this model to run at!) Could something be causing the amp to self oscillate when it's in the cab? Any suggestions or pointers for things to check would be helpful and very much appeciated!
