Should these resistors be replaced? Pic
  • Should these resistors be replaced? Pic
    They look a little used to me, but I don't know...should they be replaced?
    I've already ordered a replacement for the gold cap that's leaking (also in picture).
    I'd replace that cap, then see how it goes.
      Are you talking about the five black things with the blue lines?
      If you are, they are diodes, not resistors. Check them with a multimeter that has a diode test function.
        Where are they in the circuit? - could be burnt resistors, but it seems odd they would all have burnt in a way that the only color band surviving on all of them is the blue. Odds are they're diodes, like 52 sez, but it's good to cover bases.
        Hope this helps!
          Thanks everybody. Since they're diodes, that might be them in the bottom right corner of the schematic. I'm guessing that's an example of the diode rectification I read about a while back. It looks like the leaky cap right next to them, 100uF 50v.
          I'll try to test the diodes. I didn't see a spec for them on the schematic...anyone know what value they are?
          Here's the schematic. It's a Magnatone MP-1.
          Edit: On Line 1 of the Notes in the schematic it says something about High Voltage Rectifiers 600 PIV 600MA. Would they be the diode specs?
            Ordinary old 1000V diodes oughta be alright (1N4007)
              I tested them just like in the picture, didn't disconnect anything, and got readings of about 530 with the leads one way and 1 with the leads the other way so I guess they're good.
              Thanks again.
                1N4007 diodes will work. in the picture the four lower diodes are the B+ rectifier, the top diode and the cap are for the bias voltage. Watch the polarity when you replace these, or else you'll watch the smoke.
                  It's alive.
                  I replaced the cap, hooked up a speaker, and turned it on for about 1 1/2 hours with a light bulb in series between the amp and the wall.
                  Then tested straight into the wall and plugged in. It was pretty quiet and sounded good for the short time I played with it.
                  I'll put a 3-prong cord on it next.
                  Thanks again.
                    While you're at it, either clip the .047/600 death cap out of circuit, or replace it with a proper "safety" cap (X/Y).
