Customer brought us an early vintage Laney "Sound" 60W head for service. Came back a couple of times with the customer saying that it blows the HT fuse on him (Seems to have a tendency to overload it's EL34s, causing them to fail). I'm not the tech who worked on this originally for us, but I hear about it.
The high voltage supply is up in the high 600's, and without having been in the amp to know what the screens run at, I posited that the power supply might be stressing the newer production EL34s and maybe dropping the supply might be an appropriate measure. I told my boss that I had a salvage NTE2973 from a VVR circuit I built into one of my first amps back in the day and an a bunch of 59V zeners from a surplus lot, so we could do an install of Keen's amplified zener circuit as an option. I actually used that mosfet for that very purpose to drop the B+ on a Transformer spec'd for a quad of EL84s which I was using in an amp using only 2 x EL84s, and it worked exactly as expected.
Anyways, we got around to installing the zener/mosfet circuit today. Here is the exact schematic as modified:
So, when we powered the modified amp back up, there is only about -20V across the fet. Any idea what is going on??
