One of my steady clients brought another of their Eden WT-800 amps. Later generation model, having Neutrik NL4 output connectors, 3-pairs of outputs, chassis mounted IC 15V regulators. Complaint was fuzzy sound in HF horn. Amp wasn't set for Bi-AMP mode though. I powered it up, with just the LF/Right Ch woofer connected. Cracking the Master Volume, I heard the HF Sweep EQ band control was oscillating, with the Freq Sweep control setting the pitch of the oscillation. Amp was in Normal 2-ch mode. I powered down, disconnected cables/AC Mains. Already had the top cover removed.
I removed the FP control knobs, unplugged the harness connectors from the preamp board including the cables from the Preamp motherboard to the Sweep EQ board. Then, removed both boards for close inspection, changing to my surgical loupes and headlight.
First, I found Lead-Free solder in use, and the right-angle 4mm spaced -.062" square headers on the Sweep Frequency pots board had a lot of solder joint fractures on the headers, so using solder wick braid, de-soldered the pins and re-soldered with 60/40 Kester solder, now having clean connections. Looked at the bottom of the main PCB's connections, seeing I had previously had to restore circuit connections in correcting earlier solder joint problems. Touched up some solder joints. Then turned the board over, and my eye caught green liquid on the JRC 072D Bi-Fet Op amps plugged into tin-plated IC sockets. What's the green stuff? I haven't seen that sort of green liquid except from some cable insulation, that seeping out of the copper wire. I unplugged six of the op amps, and applied Caig Contact cleaner, brushed onto the IC sockets. On the IC leads, there was a build-up of corrosion on both sides of the leads from the base where they exit the IC body. I wire-brushed the outsides, as well as the insides, then after cleaning them with denatured alcohol, I took my X-Acto knife with #11 blade and scraped away the oxidation from both sides of the leads, brushed it off, cleaned it again with alcohol, then brushed on Caig DeOxit, and plugged them back into the 'treated' IC sockets. I've not seen this sort of corrosion on IC leads/sockets before. Used to seeing Black oxidation on silver plated leads on aged TI IC's.
I didn't think to stop and take photos of all this, now wishing I had. After putting the amp back together, I powered it up, thinking what I had encountered, that fuzzy sound they were getting fin the HF horn was no doubt from both the corrosion as well as the solder joints interfacing the Sweep EQ controls. I only connected the woofer, again to the Right Ch, still in Dual Mono mode. Turned up the master, played with the HF Sweep EQ boost and frequency control, and no more oscillation. That I expected. Applied pink noise, heard what sounded stable, and the Sweep EQ all sounded nominal.
I switched into Bi-AMP Mode, which came on with a loud Pop in the speaker, and a nasty hum that sounded like the amp was ready to fail, though no difference in the AC Mains current/wattage readings (under 600mA/60W. I immediately switched back out of Bi-Amp mode, all sounding normal again. Moved the speaker cable to the Left Ch, tried again. Same result, sounding like it's ready to fail. I haven't yet connected any instrumentation to the amp, power supply connections to see what I'm dealing with. Usually when you hear something like that, there's a huge change in the AC Mains current flow.
So....pondering the problem in Bi-Amp mode and this nasty Green corrosion found on the IC leads. It wasn't on all of them, just on six of them. First time I've seen that on the Eden amps. Client has several of these amps.
WT800C schematic.pdf
