I'm trying to figure out the bias of this singled ended tube amp.
The amp power supply has been re-capped with the values shown below the originals on the schematic. And it has a 6L6 replacing what should be a 6V6. There's a 10uF bypass cap on V5's cathode to ground in parallel with the 330ohm resistor. I don't see any other changes to the schematic.
I changed back to a 6V6 and checked the bias. (Using the voltage drop and resistance of the cathode resistor). I’m getting idle current of 62mA, with plate voltage at 375v. This seems pretty hot! tedweber.com Bias Calculator says: 6V6 in Class A with plate voltage 375v. 90% dissipation is 28.8mA
I checked the bias with a 6L6 in place out of curiosity. Idle current of 73mA with plate voltage 365v. Weber calculator says 90% dissipation is 46.8mA.
The capacitors tested ok but I replaced them anyway. I went back to stock values. I used a 47uF instead of the 20uF x2. Now, there’s a (not huge but reasonable) 120Hz hum. Reconnecting the 330uF capacitor eliminates the hum. Is this higher value capacitor safe and a good solution? Is this common practice?
Upping the cathode resistor is bringing the bias current down but not anything like enough in get it close to the weber calcuation.
Any thoughts?
Any thoughts?
