Desolder gun sponges?
  • Desolder gun sponges?
    So I have a Desolder gun with a 17mm sponge that goes behind a spring filter. The sponge looks just like the sponge used with the old soldering irons.
    Where might I find a rather large sheet of this so I can make a punch and just cut my own as they don't seem to last long before clogging.
    Thanks,
    nosaj
    Techspray CS-17. 8x16x1 inch sheets
    Techspray CS-17/625. 8x16x0.625 inch sheets
    https://www.digikey.com/en/products/...17-625/4897281
      Plato CS-17 sheet 8.5" x 17", 1" thick (when activated by water). Also has a thinner one, CS-17-625. Plato_Catalog_2016_LR.pdf (nteinc.com) Seems I bought these thru Mouser, can't recall the price, but was reasonable.
        /625 is 0.625 inch thick
        https://www.techspray.com/sponges-2
          I use a wad of fine guage wire wool, just as Metcal do.
          Cheap, plentyful and successful.
            Ours at work have a thick cotton like material and we use steel wool in front of that.
            But a regular sponge would work fine, that's about how thick the filter material is right from the manufacturer.
            You need the steel wool in front to catch the hot solder.
