Thanks for allowing me to join this forum ! I am currently on a labor of love restoration of a 1969 Kustom K200A-1 Bass Amp Head. I am going about this as logically as I can, by starting with the power section, 120vac in, thru transformer to rectifier and then off to the giant caps ! Here are my three questions....
Question #1 - By looking at the schematic (and a test doc from Don) - I should see -40vdc to center tap and +40vdc to center tap via the three (3) output leads (2 Purple/ 1 Gray CT) of the secondary winding of the transformer.... Is this correct ?
Question #2 - The rectifier was replaced sometime in the past, and is shorted... The replacement used was a S6458-2 (2H).... Can anyone suggest a good choice on a new rectifier ?
Question #3 - If for some strange reason my transformer is bad, are replacements available ? or am I just SOL ? :-)
Thanks to all.... Much appreciated !
Rick
Rick
