Hello to All,
I don't remember when I purchased my Fender Blues Jr, but it was in the 90s with the green board. Pretty sure it is a Revision B. Changed speaker to Cannabis Rex way back, not sure why. I have changed the tubes several times. Have had to resolder the tube socket board a while ago. Decided to check it out the other day. Had all sovtek tubes. One of the el84s was redplating and there was alot of scratchiness going on as well as hum. V1 was microphonic so I placed it in V3, it was bad. Had old GT (sovtek) and put it in V1. The microphonics seems to have stopped. Have a JJ12AX7 on the way. Swapped el84s and that tube still got hot quick. Placed old GT in there until I get replacements. Read numerous articles and YT videos on reported high biasing of the amp and causing the early demise of the power tubes so I decided to check it out.
Remembering the mismatched el84s
(thanks BTW for a wonderful thread in this forum on how to test the biasing !!!!!!!)
Resistance was 97 ohms on both coils. Red to Blue and Red to Brown.
Voltage difference after 10 minutes warmup was
Red to Brown = 3.39 Vdc
Red to Blue = 4.24 Vdc
If I did it correctly that is 34.9 mA and 43.7 mA
As a test I clipped a 100K Ohm resistor across R37 with the following results
Red to Brown = 2.24 Vdc @ 23.1 mA
Red to Blue = 3.03 Vdc @ 31,2 mA.
Please check my methodology and reasoning. That seems like a 33% reduction in amperage. I am hoping that the balanced pair of el84s will even the differences out ???!!!
Don't see any caps leaking. Cleaned out the board mounted cable plug with alcohol and it seemed to have stopped that scratchiness.
Wil worry about more after the tubes are replaced.
What is the current trend of thought on the biasing of the amplifier. Should I put the 100K across R37 and solder it there? Trying not to pull the boards again if I dont have to.
Thanks for any help!
