I have a 66 Super Reverb that has a non Fender replacement PT in it with no bias winding, and a higher B+ than I'd like. The bias supply is tapped off one leg of the secondary, and works well. However, I am getting a secondary of 436 - 436 vac, and B+ of 550v. When I got it, the rectifier was changed to diodes. I put it back to a TAD GZ34/5AR4. Not only am I questioning can I run this amp with such high voltages, I also don't seem to be able to find a datasheet on the TAD tube.
I have adjusted the bias down to an acceptable safe level of around 60% for the USA made Baldwin branded 6L6GCs.
what to do?
what to do?
