Using the combo as a head. The sound occurs through different cabs so I know it’s not the cab.
I swapped out 3 of the 4 preamp tubes with newer/
known to be good JJs. I swapped the 4th around work other tubes I had. El34 are new EHX. I installed the stable bias module mod on this. Bias stays stable at 90MV.
Here is a clip. Again if only occurs at louder volume. Anyone have suggestions on what else I can do to troubleshoot it?
https://www.dropbox.com/s/f0aaqrgzln...ounds.m4a?dl=0
