When I'm going thru initial check-out on Fender Combo amps, such as Deluxe Reverb or Fender Twins, for example, and come upon a very noisy tube in either the Normal or Vibrato Ch, I'll go to Standby, and remove V5 Vibrato Circuit Tube and substitute that tube in the offending input channel's tube (V1 or V2), just in case I luck out and find a perfectly quiet/working tube in the Vibrato circuit. While that didn't work in the previous 65 reissue Deluxe Reverb I had on the bench, it DID work on the one that's up there now..
Over the years, I must confess to having used this trick and saved $$ on preamp tubes. It's often like having a spare working tube on board that can be used. Is it as good as a fresh new 12AX7/ECC83S? Sounds like it is for the most part. I wouldn't do this for an input mic tube on a tube condenser mic, of course. And, if it doesn't sound up to snuff, I THEN replace the tube.
Am I the only one pulling this one, or is this a widely used trick out there?
