Heater voltage is the voltage between tube heater pins, i.e. pins 2 and 7 of power tubes.
Music Man 410-65 Service.
Originally posted by Helmholtz View PostHeater voltage is the voltage between tube heater pins, i.e. pins 2 and 7 of power tubes.
G1.. no it doesnt have a spare set of transformer wires, so Im stuck with how it is.
Thanks SC
Originally posted by Sea Chief View Post"Like a garden hose pressure will drop as you increase the water flow".. actually I don't get it. This must seem absurd to you, gnashing of teeth etc.
But if I increase the flow by opening the tap up to force more water through... I can't consider anything other than the pressure to -increase-. I'm doing my thought experiments, just like Einstein papers everywhere here etc, & nope.. I just cannot think of it decreasing in any scenario if I turn up the tap.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostTry this one. You are running the garden hose with the tap full open. You put your finger over the hose end to try to cut off the flow. The more you reduce the flow, the greater the pressure will be in the hose. If the hose were semi-elastic rather than rigid, you would see it start ballooning as you reduced the flow. That is due to increased pressure.
Thanks for your patience g1.
- Likes 1
I wonder if my higher line voltage than these designed for (220v from online info) might have upped it from 6.3 vac? Thx SC
