Originally posted by Helmholtz
View Post
The power tubes are balanced / matched. Both are same brand, same readings on a Sencore TC109. both are 106.5 & 107 Em. I use it only for matching, grid leakage & shorts.
I did not notice the (extra?) 'thin' nuts & lockwashers inbetween the chassis and powertransformer and they were loose, but the chassis nuts were tight. So I tightened them.and soon after the 120hz & 240 hz. appeared. THEN, moments later while testing the amp, alll the notes suddenly had distortion on top of them (clear note & a separate fuzz sound at the same time). Then, the low 'E' string buzzed, followed quickly with the low 'A' string warbling!
I checked every single part on the amp again. I was going bug you guys about this new problem, but then I thought, I had never taken the speaker out of the amp and actually looked at it & physically pushed on the cone to see its condition. The speaker must have went bad moments earlier. The voice coil scrapes and catches horribly. The cone cannot move back & forth smoothly. I just ordered a new replacement speaker.
I am hoping somehow, the speaker may have caused some of the hum, or no?
Sorry about the .. posts above, I was trying to revise them when I kept encountering more problems with the amp. I didn't know I couldn't put them back (the posts) later.
