I have in front of me a very pretty Gibson EH160 Amp (or so I believe). No idea on the year but it has a field coil and other signs of age but it is in very good condition.
This amp has not been powered up for some time but was reported working in the last 15yrs.
Observations...
- It has had some work with the inter-stage transformer replaced and a few electrolytics replaced.
- It has non-original 110v US 3 pin mains plug with the chasis connecteted to earth.
- Hot / Live goes to the fuse
- Neutral (as we call in UK) goes to effectively the zero star earth point where various electrolytics -ve meet.
- Green earth wire is connected to input jack earth.
Issues
When powering it up it blows my RCD but if I lift the earth (temporarily) then the amp will power up and does sound nice with a bit of hum in the background which could be improved no doubt.
My question is really about best practice on making this amp come close to modern safety standards and making sure it can be used without tripping the circuit breakers.
Additionally, I would like it to be converted to 240v operation but if the solution is to operate via an isolation transformer then that could solve two problems at once. Accordsing to the schematic, there is a 240v dropper resistor R8, which sits in a kind of rectifier socket, this one being 110 has a wirelink in there. Anybody know what the 100R 100w resistor would look like as that might be a cheap solution for 240v although sounds a bit dangerous.
Any other pearls of wisdom, history or help very welcome.
Mike
