Looking to see if this board appears to have the mod the corrects the overheating issue or any other mods?
Ampeg VL1002 MOD
So many engineering change orders involve changing a resistor value or similar, so distant, whole-board photos are not really helpful.Education is what you're left with after you have forgotten what you have learned.
I'm not familiar with mods for overheating, but rather mods for the heater wiring. I worked on one of these a couple years ago. Customer had me do the heater mods and to clip out two caps for faster switching circuitry. They are detailed in the following Lee Jackson video.
https://www.youtube.com/watch?v=MICW...nel=LeeJackson
- Likes 2
Originally posted by g1 View PostIf you have some info about an overheating mod, please post it.
This is where we need to see the real item. When you say mod to prevent overheating, a technician assumes you mean the amp overheats. But when you talk about soldering wires instead of using molex connectors, the nit sounds more like they want to avoid CONNECTOR PINS from overheating. Vastly different.
Usually the connector pins that overheat and burn are in the heater wiring. No other pins really carry much current.Education is what you're left with after you have forgotten what you have learned.
- Likes 1
Originally posted by Delta362 View PostHere are a few photos of the VL1002 that I had. Very clearly had a Molex connector problem and the previous tech soldered in some wires rather sketchy.
If you watch the Lee Jackson video, he shows the entire mod process for the heater connector mod and relay switching mod.1 Photo
- Likes 2
Originally posted by ca7922303 View PostLooking to see if this board appears to have the mod the corrects the overheating issue or any other mods?1 Photo
Pin 5 is the control grid and wouldn't likely be part of a heater mod. My bet is that the board was conductive and this is an attempt to get bias voltage stable by removing grid pin connection from the board."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 2
