I have an Acoustic 150 that has a major hum, unaffected by the controls..
If I remove the "signal in/out" wire from between the first channel (17-10) and the power amp (17-12) the hum goes away and the second channel sounds great (they basically enter the power amp at the same point).
Simple enough, but what I can't get my head around is that if I ground that same signal wire while it's connected, I get no change in the hum whatsoever. It kills the signal fine, but not the hum.
If it were something being introduced through the preamp signal wire, how does grounding it not kill the hum? If it's something from the power amp, how is it only effecting one channel? Someone please tell me I'm not crazy.
The pertinent pages on the schematic are pages 16 and 20. The signal out from the preamp (C) goes directly to the signal in on the power amp (C)
Already replaced the two e-caps and Q103 (MPSA09) on the preamp board.
Thanks!
Thanks!
