Ugh...why do these amps even exist.....
they look like homemade junk
After chasing some bad grounding that was causing horrific noise from the reverb circuit, accidentally killing one of the 4793 chips dues to really stupid chassis (if you can even call it that) design...
i have the amp working fairly well except there is no vibrato.
as you can see below it uses a lovely Vactrol VTL9A5. I get no resistance reading across the pins, is there another way to test it, or I could possibly use a pair of other Vactrols to get the oscillator working.?
The two .47uf caps were just hanging off the board at one end, thought it would be an easy fix.
Of course trying to work on this annoying thing, ch1 is now fuzzy and low volume, hopefully I didn't kill another 4793, I think I have a couple spares from an old junk rusted out Sunn solid state mixer/amp.
