First off this is not the same amp that I posted about earlier this year. I have 2 of them. I will refer to this one as “unit 2” as to not confuse with the previous one I’m still working on. I bought this amp 15 years ago for the speakers from a repair shop in Orlando Fl. selling as unrepairable for parts only. Decided to dig it out of the closet and give it a go. And as I have said before I’m a hobbyist/novice and not a well vetted tech as most of you are.
These are the items that I found initially at fault. Either shorted or burnt open and physically cracked.
Q13 & 17 shorted
R98, 112, 131, 145 – All 100 ohms burnt
R123 emitter resistor had been replaced with two 2 watt .47 ohms in parallel, one side loosely wrapped together not making good contact.
Both volume pots not original, loose and had the traces lifted and broken around them plus one had a broken shaft.
Found a solder bridge on one of the circuits and corrected it.
I source replacement pots and have made solid connections where the traces were broken….Thumbs up
I replaced Q13 & 17
Originals = TIP33C & TIP34C with TIP35C & TIP36C
After reading serval comments it was apparent that the driver transistors should be replaced also.
So Q12 & 16 were replaced with the original type TIP29C & TIP30C
All of the 100 ohm resistors were replaced
R123 emitter resistor was replaced with the proper .33 ohm 5 watt resistor.
I lifted several of the diodes out of circuit to check for shorts and all were reading as they should.
I hooked it up through my current limiter and powered on. No shorts per the bulb. Plugged in my guitar and it played but something wasn’t quite right. With the chorus and echo on it wasn’t as rich in sound as it should be. Upon inspection I noticed that I had overlooked a switching transistor literally cracked open. It was Q25, I had a replacement for it. Once replaced I powered it up without the limiter and got immediate smoke from R128 & 132. After replacing them I decided to sweep over all of the transistors again to look for shorts. This time I found Q31 shorted and R157 open. So, I repeated the process that I did with the other side of the amp. Both outputs and drivers were replaced along with R157. Also, since I replaced Q25 I went ahead and replaced Q24.
Powered up with the limiter and no shorts. Played the guitar through it while on the limiter and it sounded like it’s supposed to. The sound was very rich.
So after that I decided to check the bias of each amp side. I used dual meters and hook to both emitter resistors for the +/- of that side of the amp. Each was slightly off but adjusted to 5 mv. I let it idle each time for over 10 minutes for each amp side (with no speaker load). 2 things that I noticed and don’t know if that is normal. One amp side kept drifting slowly down approx.. 1 mv after the ten minutes. The other drifted but not as much. Seemed more stable.
The other thing I was monitoring was the temperature of the output transistors and the emitter resistors. The negative side of each amp was hotter than the positive sides. After 10 minutes R123 & 157 were reading 103 to 109 degrees F while R106 & 139 were reading 84 degrees. Being the novice that I am can you guys point me in the right direction of where to start looking to see why the temp is so different between the + and - sides?
Q13 & 17 shorted
I replaced Q13 & 17
