After a long time off it will give a low buzz then stop. So far I found and replaced a cap with a broken leg. Sparked when I tapped it. C 32. Also zener d 41 was shorted. Using a 22 v and 18 v instead of the 2 20 v zener 40 and 41. D5 has 0 voltage drop reading -50.8 on both sides. D4 reads 50.7 on r72 side and 39.3 at +High side.
In circuit d5 reads 0 ohms both directions. I still have to pull it to find if it is bad or if q6 tip107 is shorted.
2014 amp so I am using the 2012 schematic. Pic with readings before and after shorted d41 change.
MAX_115 PowerAmp_2012.pdf
Ideas?
Ideas?
