I've got an Electra Dyne here I'm installing a quad of new JJ 6L6s into. It Manual says it runs 2 tubes in Class A and 2 in AB. I don't think that is truly accurate, but the reality is there is less neg grid voltage on the two outside tubes, so of course they are running hotter than the two inner ones. Something like 40mA and 20 mA respectively. I've already installed a trimpot to adjust the neg voltage. Also, the amp has a half power switch that looks like it lifts a pair of 6L6's cathodes from ground.
So my question is, at what operating point do I adjust the bias. I was going to run the outer two around 45ma (500V plates) and let the chips fall where they may for the "AB" pair.
edyne_schem.pdf
edyne_schem.pdf
