JC120 chorus vibrato kills one speaker
    That is not really getting closer. One speaker should not work if chorus/vib is not working. So that was normal for chorus faults. Now you have just bypassed the switch.
    You need to verify the switch operation with resistance measurements.
    I would highly recommend against making any circuit changes til you fix the problem. At very least draw out how it was so you can change it back. I don't think anyone would have modified it to make the chorus/vib not work. That is what these amps are all about.
    What does W11 connect?
      It seems to me that you need to figure out where signal is present, and if the chorus/trem oscillator is working, to move further. If you have an oscilloscope that will make things much easier, otherwise you have to set up a sine wave input and probe through the circuit and compare AC voltages to the numbers on the schematic. I think Q9 and Q10 are responsible for the routing of the normal and modulated signals. Also, as I mentioned before, make sure the oscillator is running, if not not getting an output from that side makes sense.
