This amp is doing something strange. The volume drops to less than half and is very distorted. The weird thing is that it drops out when I just slap or play something on the guitar strings hard. Then it comes back on after a little bit of time, like anytime between few seconds to longer. For the longest time I thought is was a connection issue on one of the boards. I re-soldered both a couple of times. I’ve chop sticked and pulled on components but the only thing that makes it do the volume drop is hit the strings hard or some notes or chords hard..
It seems to be a problem in the power amp board because when jumping the pre amp over to another amp it works fine but inserting into the power amp in the problem is there.
I’m at the point where i think it is something inside a component that’s loose. Is this possible?
Does anyone have an idea on where to go with this, I’m at a lost?
![Click image for larger version
Also, is there a schematic for this? I’ve been able to find anything to fit this.
