Ampeg B100R again...
  • #46
    IC1 pin1 you have 0VDC, yet at pin5 you have +12.8
    I don't see any path for DC to be coming in between those 2 points, so not sure what is going on there.
    If it is socketed, just pop it out and see if pin5 still has the DC voltage on it.
    • #47
      There is always the internal path. If IC1 is internally shorted, od voltage can appear on an input pin.
      • #48
        With IC1 removed Pin 5 is at +16VDC.
        Again interesting red peak LED (D1) no longer lights up, although green signal LED flashes briefly at turn-on...
        I'm not old - I'm vintage
        • #49
          I see no path for DC to pin 5 absent an IC. ANy chance you have a solder bridge somewhere?
          • #50
            I thought I had checked that when I installed the socket, but with my shaky hands & poor eyesight there is certainly a chance. I'll check again.
            Thanks for not giving up on me.
            • #51
              No continuity between any combination of pins at IC1. Only Pin 10 is grounded, as it should be if I read schematic correctly.
              Self esteem at a new low LOL.
              • #52
                Do more checking with the IC1 removed. Any DC on the gain pot P1 ? Which side of R10 has more DC, or both sides same?
                • #53
                  A short need not be on the socket, what if the trace to pin 5 is next to some unrelated trace from somewhere with 16 volt on it?
                  • #54
                    @ g1 no DC on gain pot P1... forgot to check R10 sorry - will check after dinner
                    @ Enzo found a little whisker of solder around IC1 and...
                    TP2 is now +0.04 TP3 now -0.03 Pin5 IC1 now +0.02 and peak LED no longer on - is this progress?
                    • #55
                      That's great progress. You don't have to worry about DC on the P1 pot or R10 anymore.
                      What are DC voltages at TP's 4,5, &6 now?
                      • #56
                        Well, between messages I tested P1 - no DC... & R10 was 0.037 one side & 0.048 other side. These are really small resistors, 1/8 watt?
                        Going back out again for TP 4 5 6
                        • #57
                          TP4 +9 TP5 +19 TP6 +19 - so no change there...
                          • #58
                            With IC1 removed, what is DC at pins 12,13, and 14, also TP5 and 6.
                            • #59
                              IC1 out - Pin 12 0.0V Pin 13 0.0V Pin 14 -0.14V
                              TP5 +4.6V TP6 -7V
                              I spent an hour studying the schematic - all I learned was I should stick to tube amps, sigh
                              • #60
                                Well, the good news is that IC1 pin14 (TP4) seems to be causing the IC2 problems, so once you get TP4 straightened out, TP5 and 6 should be good.
                                Forgot to ask for IC1 pin 12 and 13 voltages with IC1 installed, please measure them.
