I picked up this amp as an attic find recently. Solid state preamp with British and American sections, and 200W tube power amp. Found that there is a stability issue that seems to be related to bad volume pots. I don't know that I have seen a circuit design like this. It seems like if the pot wiper goes open due to crud or damage or even vibration from 200W of tube output power it loses its ground reference and could lead to the kind of stability problem I am seeing. I'm wondering if there should be some sort of bypass resistors or caps to make sure there is some connection to ground, or some other mod to prevent this kind of issue.
Also, several of the volume pots need to be replaced. Having trouble finding something compatible. The preamp board mounts to the front panel via the pot shafts, so I need something kind of close to the originals with the long threaded bushing part. I would rather not have to replace all the pots. I have a feeling I am going to have to run jumper wires since I doubt I can find ones with this same pin footprint. Total shaft length is 3/4", threaded bit diameter is 3/8", body diameter is 7/8".
I haven't called Peavey and asked if they have replacements, but these were made a long time ago and aren't very common so I would not expect them too. Seems like their tech support is harder to get ahold of these days, too.
Thanks in advance,
Greg
Peavey-roadmaster-SS-11-74-Schematics.pdf
Thanks in advance,
Greg
