gibson_ga-80_varitone_schematic.pdf Hoping to restore a GA-80. First I would like to get the power supply working. Schematic is attached.
The amp is pulling excessive current with just a few volts applied from the variac. All tubes are removed except the rectifier.
If no tubes are installed there is no excessive current and the power transformer secondary is reading good voltages.
There are 6 filter caps. The two larger 20 uF filter caps do not look good. I disconnected the positive ends and clipped in two new 22 uF caps. Still getting excessive current. Could the smaller (4) 10 uF caps be causing this? I have not tried to clip them out yet.
Anything else to look for?
Thank you! MC
Thank you! MC
