Was working on one of these Custom silverface sort of re-issues from Fender. Supposed to be all the popular mods built in I guess. This one was the 68 Custom Deluxe.
It seemed to me the reverb was not as strong as what I am used to from standard blackface or silverface.
The only difference I could find in the tube circuits was as shown. I think they may have done it to get a more useable range out of the reverb pot, but it also seemed you could not get the full on surf sounds I am used to at the higher settings.
One other thing was when I measured the tank, I found the output resistance about 50 ohms, rather than the usual 200 ohms or so. Checking the schematic again, and the parts list, it was supposed to be the standard 4AB3C1B tank.
The tank did not have the number stamped in like the accutronics do, but had a label that was covered up by the stick on hook for the reverb cable. I pulled that off and found the number to be RRVL2AB1C1BV4. This is a Ruby branded Belton tank. A bit of digging tells me this is what Fender is using now in several amps such as Deluxe re-ish, this 68 Custom series, and others where the schematic shows the regular 4AB number.
So they are using a 'short' delay instead of 'long', and the output resistance is quite a bit lower. Magic parts calls the output impedance 150ohm but I don't think that is correct. More likely 1150 or 1500ohm impedance I think. (4AB output impedance is 2250 ohm).
So heads up in case you run into a Fender tank that measures 'wrong' resistance at the output end, it may be the new normal.
Not sure why Belton would think they can just change what 'B' means for output impedance, but they seem to have done it. https://shop.magicparts.com/ruby-rev.../RRVL2AB1C1BV4
